I was thinking about buying it to use with VDJ.
Is anyone using it them together?
Does it work well?
What are the problems, if any?
Thanks
Does it work well?
Thanks
Posted Mon 10 Nov 08 @ 11:57 am
Hi I am using Virtual DJ With Xponent no problems at all. Virtual DJ has full support for the Xponent and SBDJ has uploaded his own XML template to work with Virtual DJ and i think its a lot better. Good luck
Posted Mon 10 Nov 08 @ 1:47 pm
when i was in the market for a controller, SBDJ rec'd the xponent as well, but due to budget constraints i went with the RMX. now i am wondering whether i should have went with the xponent as i am still unable to map the RMX. the main thing with the xponent is the plastic construction and the lack of a mic input or the ability to input timecodes via rca jacks. the cool thing is that it has a touchpad, and the jog wheels are above the buttons which may present problems or not i am unsure. i am wondering though, how efficient is the mapping with the xponent and VDJ and have you had any problems/gremlins etc.?
Posted Mon 10 Nov 08 @ 5:43 pm
I read that the LEDs only light up when you use Torq.
Is this true?
Is this true?
Posted Mon 10 Nov 08 @ 5:47 pm
No the Leds all work on the xponent as i have said there are no problems with this midi controller.
Posted Tue 11 Nov 08 @ 2:20 am
Hi
both VDJ and xponent are great. You definitely need native mapper / created by SBDJ only/ . I dont like torq and my Hercules is in the box for a year because of cheap and unreliable buttons. Minus is missing mic input on xponent but for others it can be different story.
Buy and enjoy it.
Buy and enjoy it.
Posted Tue 11 Nov 08 @ 3:54 pm
Virtual DJ With the Xponent is the way to go man , I love it. No mic is right and no line in but!!!!!!!!!
This is what I did (Only $30) One line for mic or two in one for a CD player (if you need one)
http://www.radioshack.com/product/index.jsp?productId=2102920
Posted Tue 11 Nov 08 @ 5:11 pm
Hi
I just got the M-Audio and everything seems to be working except the headphones.
Can Anyone tell me how to make them work?
Thx
Thx
Posted Thu 07 May 09 @ 11:38 pm
First make sure you've got the latest drivers, and that your xponent is working as it should.
Then you go into soundcard setup and set "Xponent 3/4" as your headphone out. If it's still not working make sure that the volume knob in the middle is turned up.
Posted Fri 08 May 09 @ 12:36 am
okay now my headphones work too! but, if I search through a song (by turning the "vinyl" pad) there is this sound... what is this? it's this stupid sound like a needle that is on a vinyl... help me!!! I can't dj with this sound in the back!!!! pls reply!!
Posted Fri 23 Oct 09 @ 4:02 am
