Hello there,
I'm using TCVs with the Herc RMX and an external mixer, when I use the TCs there is a definate drop in sound quality, which is then restored when I disable the TCs.
Is there any settings you think I should change, could it have something to do with the old stylus' that are being used?
Any help much appreciated.
Posted Mon 10 Nov 08 @ 10:20 am
I had the same issue at 2ms latency in asio mode. I had to go to 4 ms. Whatever your are set at right now, raise the latency up a bit.
-David
-David
Posted Mon 10 Nov 08 @ 2:13 pm
sorted, thanks david.
Posted Wed 12 Nov 08 @ 7:26 am
