Hi;
I recently bought my copy of the mac version, the beatmatching worked fine at the beginning but afterward i had problems using it. It never beatmatches/synces nicely anymore no matter what i do. Deck A and deck b with any track so ever dont beatmatch anymore. I get these weird sounds even though visually, I can see the bars perfectly on top of each other. It sounds like the kick's somehow break.
I cant record anything like this.
please tell me how i can solve this problem
regards
regards
Posted Sat 08 Nov 08 @ 3:11 am
Do u use any controller? Try untick the keylock n see if the problem persist..
Posted Sat 08 Nov 08 @ 4:41 am
the keylock is unticked and i dont use any hardware :(
Posted Sat 08 Nov 08 @ 6:16 am
In performances, set to fastest, auto on latency n this time tick the keylock too. On master tempo set to fast.
Posted Sat 08 Nov 08 @ 8:03 am
still couldnt get anything out of it:( I dont have this problem on pc
Posted Mon 10 Nov 08 @ 5:34 am
Hi..check ur PM.. I send my msn to u n will try to help u via there.
Regards.
Regards.
Posted Mon 10 Nov 08 @ 6:12 am
I´m having the same problem, it´s like the beats cant catch up with the signal so the music is clicking and skipping beats and sounds.
And I´m using a 2.5 ghz macbook pro with 4gb RAM so I don´t think the CPU power is too slow. :(
Posted Mon 29 Dec 08 @ 4:57 pm
Hi there.
It's best u reigstered ur serial n updates to the recent version V5.2.1.
Regards;)
Posted Mon 29 Dec 08 @ 9:19 pm
