HP Pavilion Laptop with Intel® Core™2 Duo Processor T5800
SPECS:
Processor Brand Intel®
Processor Intel® Core™2 Duo Mobile
Processor Speed 2.0GHz
Display Type WXGA high-definition widescreen with HP BrightView technology (1280 x 800)
Screen Size 14.1"
System Bus 800MHz
Cache Memory 2MB on die level 2
System Memory (RAM) 4GB
Hard Drive Type Serial ATA (5400 rpm)
Hard Drive Size 250GB
Optical Drive Double-layer DVD±RW/CD-RW
Graphics Intel® Graphics Media Accelerator 45000MHD
Video Memory Up to 1759MB total available
S-Video Outputs none
PCMCIA Slots 1 ExpressCard/54
USB 2.0 Ports 2
IEEE 1394 FireWire Ports none
Operating System Windows Vista Home Premium 64-bit with SP1
i bought this and installed the mk2 hercules drivers and djc virtual dj......................It did not work :(.........so im going to buy the RMX.........and i need to know if it will work with this laptop since it did not work with the mk2
SPECS:
Screen Size 14.1"
System Bus 800MHz
USB 2.0 Ports 2
Posted Fri 07 Nov 08 @ 6:09 pm
There is no reason why not. MK2 and RMX should work ok, you had problems elsewhere, might be the driver.
Posted Sat 08 Nov 08 @ 7:52 am
if the mk2 doesnt work the rmx probably will not work either. mostly from what i have read, in many cases the mk2 synchs better with VDJ than the rmx. if you want to run video with VDJ i would determine shared vs. dedicated video ram, as i had a similar setup and the video licked balls without a dedicated video card. everything else looks good for audio. as djalf recs, check out the driver updates on all sides: soft/hardware.
Posted Sat 08 Nov 08 @ 2:44 pm
