Fairly new to this and the boards.
I upgraded virtual dj to 5.2 and I cannot get as precise bpm as I used to (used to go up approx .1 clicks) and some of my buttons are remapped and don't have the same functions as before.
I tried re-installing both virtual dj and the drivers but nothing is working, any help would be great! :)
Posted Tue 04 Nov 08 @ 2:50 pm
You better try to use the ASIO mode.
You can look HERE in my blog.
Hope this will help you.
Posted Tue 04 Nov 08 @ 7:12 pm
Hey the link isn't working for me for some reason, do you think there is another site that could help me out?
Posted Wed 05 Nov 08 @ 3:29 pm
Register your serial # HERE and you can see my blogs.
You are a "no license user", and if you have the MK2, you got to have a serial #of virtual dj, and you will become a registered user.
Posted Thu 06 Nov 08 @ 1:49 pm
Hello Waterwings,
If you use VirtualDJ DJC 5 with DJ Console Rmx,
- you can change the step of the pitch fader by clicking on the percentage figure written on VirtualDJ DJC skin between the pitch slider and the Syn button
- you should read the VirtualDJ DJC 5 user manual, which you can download on http://ts.hercules.com/eng/index.php?pg=view_files&gid=2&fid=28&pid=215&cid=6
Posted Fri 07 Nov 08 @ 5:35 am
