Topic: Need help with skins
I just purchased VDJ home edition- installed- registered the product. When I download a new skin(from the download center) it comes in EFW. Format and I can’t do anything with it. I notice in the trial version there was a folder called skin and that’s where I could find the files. When I open my VDJ I find a exe. And the uninstall file along with crash guard and two readme files. AM I missing something?
Any help would greatly be appreciated
Posted Tue 04 Nov 08 @ 2:06 am
It's extrange, because the skin files comes in .exe format.
You have to execute and it install on the correct folder.
Are you sure you are downloading the skins from HERE?
