hello all, just recently ive noticed ive been having a little audio problem with my mk2. i use the mk2 mainly for its soundcard, it gives a great sound and loud.
i have a small problem tho.
i use the red and white cable( audio cables), i put them into the bak of the of the mk2, output 1/2 and i get a humming noice, i get it in both outputs 1/2 and 3/4. its a humming noice, like as if the the connection is really secure, but it is, to both my mk2 and my audio reciever. wat can b the problem? i also tried different audio cables so i dnt think thats the problem. i gave my mk2 to a buddy and he also had the same problem, so i dnt think my mixer is the problem, wat can b the problem?
Posted Mon 03 Nov 08 @ 10:57 pm
Do not double post as u have ur answer in the general forum. Thanks;)
Posted Tue 04 Nov 08 @ 4:18 am
