I have a laptop with windows XP sp3. I am trying to use timecode cds with 2 pioneers DVJ-1000s and an m-audio connectiv soundcard. I am getting 100% signal but it wont cue, it jumps around, the pitch does not move when I move it, and other problems. I don't have the latest drivers because the m-audio site is giving my problems. Do you guys have any suggestions for me?
Posted Sat 01 Nov 08 @ 7:45 pm
make sure u select cd or vinyl in soundcard /timecode window..
also on torc soundcard try auto config for timecode and try adjusting the volume on soundcard all the way to the left etc...
hope this helps
hope this helps
Posted Sun 02 Nov 08 @ 1:15 pm
I did select cd, I did turn the nobs, etc.... I am waiting to get the new drivers, as soon as they e-mail them to me, to see if that works.
Posted Sun 02 Nov 08 @ 3:29 pm
Well, still having problems with downloading the drivers. Even when the guy tried to send me them. I need this one Conectiv_V32_5.10.00.5112v2.exe
This is getting very aggrevating..........
Posted Mon 03 Nov 08 @ 10:34 pm
Maybe something simple, but have you disabled master tempo on your DVJ? :)
Posted Tue 04 Nov 08 @ 4:32 am
no I did not, I will have to try that..
Posted Tue 04 Nov 08 @ 8:33 am
