I'm not really a mobile guy, I have my weekend gigs which I'm happy to do,
But since I've been using VirtualDJ I have been asked to do a few friends and family birthday parties and that sort of thing, which I also like doing, as it is a change from my club and bar gigs. So what I've been thinking in doing is spending some cash (not that much I hope, I want my CDJ's, first, lol) in a small mobile "pub" set up.
I've been lucky because the pubs, where I've done this parties have had there own sound sound, so all I did was plug my RMX into there system and play, but I would like to become self sufficient.
So what sort of equipment, (nothing special but something that would do the job) would I be looking at for the small set up. Any advice would help.
Posted Wed 29 Oct 08 @ 12:00 pm
Go look at my blog Jimmy..I posted pictures of a very small set up.....add speakers and run with it.....
Posted Wed 29 Oct 08 @ 12:17 pm
Yep Terry, perfect, that sort of set up would do me nicely,
What sort of power output would I need for a general size pub, smallish function rooms and say 100-150 guests.
Posted Wed 29 Oct 08 @ 12:29 pm
sent you a pm... it's our little secret, lol.
Posted Wed 29 Oct 08 @ 12:34 pm
For crowds up to 125 I use my Mackie SRM 350s. For groups larger I use my SRM 450s. If more punch is needed I add my subs. I have a 12 inch and a 15 inch sub...I used that set up you see in my blog and my SRM 450s and 15" sub at a wedding with 350 guests..and it worked very well....I have used just my SRM 450s and that set up for a group of 160 two weeks ago and it was the bees knees....I run a Behringer Xenyx 802 mixer into the Mic input of the RMX and that gives me up to four mics for the guests to use....
Posted Wed 29 Oct 08 @ 12:35 pm
I personally think the 350 are a little underpowered if you are only going to have one settup.
go with the Mackie SRM 450s and Tear's small setup and you should be fine.
I tend to overdo things so my small setup is pretty large. I use JBL PRX 515 Powered Speakers (2)
and and Mackie SA1521s(2).. if I need more Bass I add my Dual Peavey Lowe riders 18" Powered by QSC RMX 2450s
The SRM 450 Rocks, it's small and very portable; another option is the JBL EON G2... they rock also.
Thanks,
DJ SMG!
Thanks,
DJ SMG!
Posted Wed 29 Oct 08 @ 1:09 pm
Cheers Terry, good advice as always.
@haz0rd, I like JBL's too mate. Not bothered what people say about them, I think the kick some arse.
Posted Wed 29 Oct 08 @ 2:15 pm
Why Does my Left deck on Virtual dj sound louder than the right deck????
Posted Wed 29 Oct 08 @ 3:17 pm
Check your cross fader settings. if your using an external mixer make sure it's disabled!
Posted Mon 07 Dec 09 @ 2:37 pm
your question would have had more response sonido if you had opened a new thread instead of asking that question in a totally unrelated topic.
Posted Mon 07 Dec 09 @ 3:37 pm
