Topic: HELP WITH MY NEW PC CONFIGURATION
I AM SETTING UP MY NEW 2U RACK COMPUTER..HERE IS WHAT I HAVE COME UP WITH FROM TIGER DIRECT AND NEW EGG
1 iStarUSA 2U 4BAY RACKMOUNT 460W PSU BLK AL. BZL
1 ULTRA MD2 5.25" 4 PORT, USB 2.0 & CARD READER R2
1 OCZ SLI 4096MB PC6400 DDR2 800MHz (2x2048MB
1 XFX GeForce 9800 GX2 1GB PCIe w/Dual Link DVI
1 Asus M3N-HT Deluxe nForce 780a SLI Socket AM2+ MB
1 AMD Phenom Quad X4 9550 2.2Ghz 4M Socket AM2+ CPU
1 Seagate 1TB Serial ATA HD 7200/32MB/SATA-3G
1 Sony 20X DVDRW IDE Retail
1 Masscool AMD Sempron 3300+, Athlon64 4000+ CPU Fan
1 Ultra Silent 80mm Dual Ball Bearing Fan
1 Asus Xonar D2X 7.1 PCIe Sound Card
BEFORE I PLACE THE ORDER CAN ANYONE TELL ME IF YOU SEE ANY PEICE OF HARDWARE THAT THEY DONT LIKE. THANKS FOR YOUR TIME.
Posted Thu 23 Oct 08 @ 3:54 pm
jesus.
that sounds like the monster setup. if you have the cash pull the trigger.
send me one.
i started out with a fisher-price and a lite-brite.
depending on whether you are going to be running timecodes, if your controller doesnt have a sound card or stereo inputs, you may want to think about, and i am unfamiliar with the xonar, getting a sound card with two stereo inputs and two stereo outputs--like, i believe, the maya44, or other cards have.
dont drop it.
Make sure you run Vista. I personally would trade the Nvidia graphics card for the ATI HD4850 or HD 4870. I have the 4850 and love the card. MAke sure your PSU is above 600w and has at least 2 12 volt rails.
