Hi guys
I just upgraded my Virtual DJ to the pro version.
Each time I open the program, I get this message:
Protection error %i. Please contact us on https://virtualdj.com/contact/
And yeah, I contacted Virtual DJ - but I have not recieved a ansaw yet :-/
Please help me,
Hans Peter
Please help me,
Hans Peter
Posted Tue 21 Oct 08 @ 4:18 pm
Its a problem with an earlier crack version most likely ;)
Just wait for your e-service ticket to get answered, as they have the tools to help you
Posted Tue 21 Oct 08 @ 5:23 pm
You have been sent a reply to your ticket.
The problem is most likely you used the limited edition serial with your pro install.
Just follow the ticket info I sent and we will get you back up and working on your MAC soon.
Posted Tue 21 Oct 08 @ 5:44 pm
Great, now the Pro version is activated!
But now I can't use my RMX in the program? And I do not get any warnings at all? :s
help a newbie, pls :)
Posted Wed 22 Oct 08 @ 7:33 am
hi , i have that problem with my virtual dj that is every time i use a knob in the programe it makes a noisy sound which miss up my whole mix so plz can u help wiyh that .
thx.
thx.
Posted Wed 22 Oct 08 @ 8:06 am
you need to update all your hercules drivers if you haven't already done so, then you need to re-scan your files also if you have just updated to 5.2.1... then try these settings, if you are using an external mixer set the sound card to 4.1. great post in the tech section for more of other users different settings that may suit your set up.
Posted Wed 22 Oct 08 @ 8:36 am
Thx.. But I'm having problems with downloading news drivers on hercules website? .. they won't start, and my internet works just fine?
Posted Wed 22 Oct 08 @ 8:52 am
hi guys i have 1 problem!!then i put the usb in post open 1 message!!
"Please disconnect and then reconnect the USB cable on the back of the Hercules Dj devise(the one identified iwth the CUE and PLAY/PAUSE LEDs On).and i want to download the new update firmware!!How?please 1 help me!!
Posted Wed 22 Oct 08 @ 11:06 am
@hansharmlös, you will have to persevere at the hercules site, they must be having some problems, try again in a little while.
best to always make sure all connections are made before booting up.
Posted Wed 22 Oct 08 @ 12:00 pm
Wow thread hi jackers.....
Posted Wed 22 Oct 08 @ 1:35 pm
what are you on about "thread hi jackers", can't you read, the guy that originally posted is having associated problems with the rmx,
Posted Wed 22 Oct 08 @ 1:42 pm
Just wanted to thank you guys for your help!!!
Posted Wed 22 Oct 08 @ 10:54 pm
@ sbhoopsfan my apologies mate, saw the comment and apparently i can't read, lol.
@ chris, bollock's, i dropped a booby, that is not my gig lappy but the home pc and i forgot to re do the settings on it, thanks for pointing it out i will scrub this one, me dumb.
Posted Thu 23 Oct 08 @ 3:59 am
