Hi there
Apologies if this has been answered a number of time. I tried logging a support question and got told to post here.
here is the problem
i use virtual dj with my new rmx mk2 but when i broadcast i cant seem to get the mic to broadcast, it sounds like its working out of the system but not broadcasting. Can you lend a hand please?
Everytime i set the mic to hercules when i click broadcast it says no sound detected and I can use the soundcard on my pc and it needs to come from hercules. Can anyone advise how to overcome this?
thanks
Sean
here is the problem
thanks
Sean
Posted Mon 20 Oct 08 @ 9:03 pm
In the Config tab above broadcasting make sure your sound card is Master + Mic and make sure the MK2 is selected as primary sound card.
Posted Tue 23 Dec 08 @ 11:54 am
Thanxxxxxxxxxxxxxxx
Posted Fri 20 Mar 09 @ 10:55 pm
but, how to use it?? n how to mute mic when the song was playing??
or just like push to talk..wht i must to do??any one know??
Posted Thu 11 Jun 09 @ 5:02 am
There are many ways: :-)
-Use the linefaders to mute the songs
-Use the plugin for users in the download area
or
-Use a mixer with a talk over function
or
Posted Thu 11 Jun 09 @ 5:14 am
Does this apply for the Macbook pro as well?
Posted Mon 20 Dec 10 @ 6:42 pm
Heres the script I use for a talkover switch,
"master_volume 50% while_pressed & deck 4 linein mic on & down ? deck 4 linein mic on : deck 4 linein mic off"
For this to work you must assign the mic to a deck with a shortcut like this,
go into mappers pick "M" and then type in "deck 4 linein mic"
Hope this helps
Huey
Hope this helps
Huey
Posted Tue 21 Dec 10 @ 12:04 am
Config --> Mappers --> make a mapping to whatever "Key" you want (I use "M") then map it to the "Action" "mic"
Posted Sat 11 May 13 @ 9:20 pm
Wo finde ich bei Virtual DJ Broadcast Push to Talk
Posted Sat 29 Mar 14 @ 2:33 pm
Sorry, this forum is for English language messages only.
Please either post your message again in English or use the correct language forum: http://www.virtualdj.com/forums/6/German_Forum.html
NOTE: This forum is for discussion about VirtualDJ Radio only. For software/hardware technical support, please use the appropriate forums.
Posted Sun 30 Mar 14 @ 11:36 am
"Config tab above broadcasting make sure your sound card is Master + Mic"
I cannot find this function
Posted Mon 06 Mar 17 @ 1:24 am
The text you quoted was written in 2008, so it refers to VDJ 7. Presumably you are using VDJ 8.
Posted Mon 06 Mar 17 @ 6:21 pm
