Here's one for you pro's...
I received some ambient avi's but I can't seem to get them to load in Clipbank. When I load it the box then says "error". I have no problem with VOBs. The decoder for AVI is set with Video Decoder. I even tried Windows Media Player Video Decoder and that didn't work as well.
Any clues?
Thanks!
Any clues?
Thanks!
Posted Mon 20 Oct 08 @ 5:07 pm
Try converting them to MPEG.
Posted Mon 20 Oct 08 @ 7:04 pm
but I thought VDJ could handle avi...???
Posted Mon 20 Oct 08 @ 8:21 pm
It can - remember though that the clipbank plugin isn't part of the main program so I don't think it's affected by the codec tab.
What actual codec are the files?
Posted Mon 20 Oct 08 @ 8:37 pm
codec of the files..?? not sure if I understand ya there. all I know I'd the extensions are .avi and .vobs work.
a friend of mine uses the same avi files and his play just fine.
a separate question sb...isn't there a plugin that will randomly select files within clipbank to run...like say 60 secs then rotate to another ambient?
Posted Mon 20 Oct 08 @ 10:09 pm
AVI is just a container, the actual video codec (divx, xvid etc...) is whats important. Open it in something like GSpot to find out if you dont know.
Yes there is a random clipbank plugin available for download.
Posted Tue 21 Oct 08 @ 5:30 am
