Since many years I use a Hercules DJ console with VDJ. Since I upgraded to the lastest HDJC software I have the following problem.
If I launch VDJ, both the sliders and the knobs influence the pitch while before the sliders were for volume and the knobs for pitch adjustment. If I go into the config controllers page and select the HDJC with a right mouse clic, I only get the choice to invert the pitch/volume selection but this does not help as then neither the volume nor the pitch then work with the sliders/knobs.
I am basically looking where I can individually assign that the sliders should be for volume and the knobs for picth. Now I do not have any volulme control on the two seperate desks. I could get around it by probably using the 1/2 and 3/4 output and connect to mixer, for individual volume control of the two VDJ turntables but then I do not always use a mixer and it used to work before.
My HDJC is first generation. Virtual DJ is latest version.
All help is welcome. Many thanks in advance for your time.
johan
johan
Posted Thu 16 Oct 08 @ 10:47 am
