How do i install a skin for virtual dj ?
Posted Sun 12 Oct 08 @ 6:41 am
Download chosen skin. After skin downloads click on skin to install. Then open Virtual DJ software. Go to config then skins. Click on desired skin and then ok. If skin doesn't work, skin may not be compatible with virtual dj version you are using.
Posted Sun 12 Oct 08 @ 11:41 am
