Hello. I am having problems configuring my headphones output with finalscratch
I am using stanton finalscratch interface with VDJ. My finalscratch interface has two RCA outputs and a headphones output. When I use the ASIO Driver and headphones output option under the sound setup, I can only select one of the two RCA outputs as my headphones output. There is no option to use the 'headphones output' in finalscratch as my output for my headphones.
The only way to get around this is to select "2 cards" under the sound card menu and then select one of the RCA outputs as my master and then the "Finalscratch Headphones Output" as my output for my headphones.
What can I do to fix this? I hope I've made sense. Would really appreciate if some1 could help me. Thnx!!
Posted Thu 09 Oct 08 @ 3:17 pm
Hi djsonance, u may not have to post in three difference forum;) It will cause confusion. A post in the asian forum and the PC tech support forum on the same issue is enough;)
You have my reply at the asian forum.
Posted Thu 09 Oct 08 @ 3:27 pm
Please do not multi-post in the future. I left the post in the asian forum you started open.
Posted Thu 09 Oct 08 @ 4:10 pm
