Updated drivers for the soundcard and firmware for the cd drive. Will have a play about with vdj later on to see if things work.
Fingers crossed.
Thanks for your help mate.
Fingers crossed.
Posted Wed 18 Feb 09 @ 7:40 am
Good luck. I tend to run with almost everything disabled - although I do leave wireless and bluetooth on as I often use bluetooth during my gigs.
Posted Wed 18 Feb 09 @ 7:45 am
I got kind of a similar issue. I had an XPS M140 with XP and it ran fine. I just bought a new laptop and the music skips like every 5 to 10 secs. I dont understand if this is a Latency problem or Hercules RMX issue. Am running WDM on the setup.
224-1941 1 XPS 1640, Intel Core 2 Duo P9400 (2.53GHz/1066Mhz FSB/6M L2 Cache)
320-7330 1 Obsidian Black High Gloss Finish with Leather XPS 1640
311-9978 1 8GB, DDR3, 1067 MHz 2 Dimm forXPS 1640
320-7329 1 16.0 inch Wide Screen 16:9 1080p FullHD RGBLED LCD W/2.0 MP, XPS 1640
320-7337 1 ATI Mobility RADEON HD 3670 - 512MB
341-7912 1 320GB 7200 RPM SATA Hard Drive
420-9319 1 Microsoft Windows Vista with SP1 Home Premium Edition 64-bit Edition English
330-1917 1 DELL RESOURCE DVD,BACK-UP XPS 1640
420-6576 1 DELL WELCOME,Software Dimension/Inspiron
420-9100 1 Dell Dock Consumer
463-2282 1 Dell Owners Manual installed on your system,click on icon after system set-up to access
420-6436 1 Vista, PC-Restore, Dim/Insp
420-7938 1 Dell Connect 2.1
421-0092 1 DELL-DOWNLOAD-FLAG
421-0323 1 Windows Live Search,Multiple User Interface
430-2600 1 Integrated 10/100 Network Card
410-1883 1 ADOBE READER 9.0 MULTI- LANGUAGE
313-7054 1 8X DVD+/-RW Slot Load Drive for XPS1640
420-9850 1 Roxio 10.2 DE
420-9334 1 Cyberlink PowerDVD DX 8.2 for DVD
313-4783 1 Integrated High Definition Audio 2.0
430-2955 1 Intel WiFi Link 5300 802.11AGN Half Mini Card
410-1839 1 McAfee Security 9.0, 3-Year Subscription
312-0811 1 56 WHr 6-cell Lithium Ion P Primary Battery, for XPS 1640
412-0148 1 No ISP requested
420-8051 1 Microsoft Works 9.0, English For Inspiron
950-3338 1 2 Year Limited Warranty
993-3488 1 Dell Hardware Warranty PlusOnsite Service, Extended Year(s)
993-3487 1 Dell Hardware Warranty PlusOnsite Service, Initial Year
986-0561 1 Third Party At HomeService, 24x7 TechnicalSupport, 1 Year Extended
992-4500 1 Third Party At HomeService, 24x7 TechnicalSupport, Initial Year
902-0941 1 Warranty Support,1 Year Extended
960-8710 1 Warranty Support,Initial Year
412-0360 1 Soft Contracts - Banctec
988-7707 1 2GB DATASAFE ONLINE 1.1 FOR SDO/DIM/INS/XPS
988-0099 1 To activate your online backupaccount, go to Start, Programs, DataSafe Online
420-9518 1 DATASAFE ONLINE 1.1 2GB FOR DIM/INS/XPS
330-0171 1 S and P Drop-in-Box Marcom forDHS Notebooks
430-3206 1 Dell Wireless 370 Bluetooth Internal (2.0+Enhanced Data Rate)
320-7618 1 Premium HD WLED Display Obsidian Black, Leather 1.3 MP Webcam
420-8223 1 Dell Video Chat
420-9330 1 Dell WebCam Central 1.0 XPS 1640
420-9699 1 Facial Recognition Sensible Vision
310-8628 1 You have chosen a Windows Vista Premium System
330-1062 1 Intel Centrino Label
Posted Wed 18 Feb 09 @ 1:18 pm
Oh no.
Left the laptop on last night but it got unplugged and so ran out of battery.
Went to boot up today and the two hard drives have failed.
It booted up eventually and I can get on the net etc and am backing up to external at the moment. This is the problem. Anyone had this before? Hope it's not too serious...
Posted Thu 19 Feb 09 @ 9:09 am
wtf!
Seems both of the harddrives have failed.
Apparently I can delete the raid 0 volumes but i might need to completely reinstall the operating system.
I've only had this laptop for about two weeks.
Posted Thu 19 Feb 09 @ 11:24 am
Thats the problem with RAID-0, losing one disk will render your whole array trashed.
Don't know what's happened with yours - could be some corruption due to the power outage.
Posted Thu 19 Feb 09 @ 12:08 pm
I'm not really familiar with Raid-0 to be honest. Never had any issues with my last Dell Inspiron laptop which I had for five years.
So what are my options?
Should I delete the raid volume create a new raid 0 and reinstall the OS?
Or are things much worse than that?
Posted Thu 19 Feb 09 @ 1:14 pm
Depends if it's a hardware failure or not.
If you reinstall, I would personally ditch the RAID, and just run it as two seperate drives.
Posted Thu 19 Feb 09 @ 8:49 pm
Update:
Managed to get help from Dell support in India and everythign is fixed and the harddrives are fine.
PHEW.
In terms of using Virtual DJ I have noticed that I can use it fine without clicks distrotions or skips if I do not have it set up to play timecodes. This is good for me as I can use the sigmatel on board soundcard for microphone use on my radio show.
I can also play vinyl through the hercules if I change the source setting on the herc from pc to turntable. I just couldn't EQ it or increase the gain. Not great but I could accept it.
Perfect i thought. Problem solved.
Well almost.
I can broadcast with no audio problems (no distortions etc). The mic works fine but without Virtual DJ being set up for Timecodes it doesn't broadcast the vinyl output even though I can hear it on my home system.
Bugger.
So close but yet so far.
back to the drawing board.
PHEW.
Well almost.
Bugger.
Posted Tue 03 Mar 09 @ 5:00 am
I have ran into the infamous Dell laptop issue also. I purchased an Inspiron 1525 on Feb 14, 2.2 processor; 4 gig ram; 2mb cache, and I have had issues with latency since I first turned it on. I have disabled all of the drivers I can think of including the battery saver mode along with the wireless and still have issues with the sound dropping out. I contacted them today and they e-mailed me a return label. I am able to return for a full refund with no shipping charge. I need to know what other laptops people have had really good luck with. I have a gig on the 14th and I need to buy a new laptop in the meantime. I am looking at both the Sony and Toshiba's. Has anyone else had luck with either of these? The pricing is about $150 less than what I paid for the Dell. Thanks and God Bless.
Posted Tue 03 Mar 09 @ 12:24 pm
I couldn't take it anymore, and it was getting worst so I bought a Inspiron 1525 two weeks ago. It's running Vista Home Premium. Just the standard 1525 on the Dell website. I now have clean, clear sound. I did have to disable the wireless card, but now I have good music with no distortion or drop-outs. No spikes at all. I'm trading a girl I work with my Studio 1535 for a 9' Pool Table. I'll get some use out of that laptop yet...
Posted Tue 03 Mar 09 @ 1:01 pm
i got the same problem on the DCP but not has bad as ur, i have the dell studio 1535 for over 7 mouth i couldn't figer it out,I try everything , i call dell i spend about 1 hour in phone, and i just got the audio 4 dj i was trying to use traktor with this laptop but it inposible and i had before the console Rmx but i had to bring it back because it wasn't working properly the Asio, but the virtual dj it work good....
if you fine out how to solve the problem let me know.
Posted Wed 13 May 09 @ 10:40 pm
Try suspending the ACPI.SYS thread.
There is a thread on another forum somewhere, I'll see if I can find it...
Posted Thu 14 May 09 @ 4:50 am
Can't believe my thread is still going.
Left the Dell systems behind me many months ago (last Nov IIRC), bought an HP G70 17" laptop, works great!!! :-)
Posted Thu 14 May 09 @ 5:26 am
If anyone is thinking of purchasing a Dell Laptop in the UK, a quick tip.
Use the website to chat live to a salesperson to ask questions about the laptop. State what you want to use the laptop for. Save the conversation (there is an option to do this when using Dell live chat)
If the salesperson says it will do the job you are purchasing it for and it doesn't, then it is not fit for purpose under the sale of goods act. This stands with an oral statement made by a salesperson in a shop, but it can be hard to prove. The beauty of the Dell live webchat is its all printed out as proof after the conversation.
Gary
Gary
Posted Wed 27 May 09 @ 6:34 pm
That only works with XP. Seems to work well, too, from what I've read.
Can't disable in Vista, though...
Posted Wed 27 May 09 @ 7:18 pm
Yup - thats what it says in the thread...
Posted Thu 28 May 09 @ 3:41 am
I'll Chime in,
I chatted with dell today and had the rep send me a email of our chat session.
Key questions "Will VDJ work with Audio+Video on this system, with my Hercules RMX", he put me on hold and after researching he answered
"absolutely!"
Here is what was offered to me (Let me know what I don't need if I actually order this, which I probably won't)
224-52123
XPS 1640, Intel Core 2 Duo T9800(2.93GHz/1066Mhz FSB/6M L2 Cache)
320-7330
311-9487
4GB, DDR3, 1067 MHz 2 Dimm forXPS 1640
320-7329
320-7337
341-7912
420-9319
330-1917
420-6576
420-9100
Dell Dock Consumer
463-2282
420-6436
420-7938
Dell Connect 2.1
421-0092
DELL-DOWNLOAD-FLAG
421-0323
421-0187
Dell Support Center Software 64 Bit 2.0
420-9691
DataSafe Local BackUp 2.0 Basic
430-2600
410-1883
313-7054
420-9850
Roxio 10.2 DE
420-9334
A1994353
ExpressCard Sound Blaster X-Fi Laptop Sound Card
430-2955
410-2087
McAfee Sapphire MUI, 36-Month
312-0811
420-8051
950-3337
1 Year Limited Warranty
993-3487
992-4500
950-9797
No Warranty, Year 2 and 3
960-8710
412-0360
988-7707
988-0099
420-9518
330-0171
320-7618 1 Premium HD WLED Display Obsidian Black, Leather 2.0 MP Webcam
421-0464 1 Dell Webcam,1.2
330-1757 1 Intel Centrino 2 Label
468-2705 1 $50 Dell Promo Gift Card Arrives in 6-8 wks, carries a 90 Day Exp. Dell.com/giftcard
420-9800 1 Dell Remote Access free basic to access your PCs from outside your home
993-1919 1 Dell Remote Access, free basic service - access your PCs and files from outside your home
"absolutely!"
224-52123
320-7330
311-9487
320-7329
320-7337
341-7912
420-9319
330-1917
420-6576
420-9100
Dell Dock Consumer
463-2282
420-6436
420-7938
Dell Connect 2.1
421-0092
DELL-DOWNLOAD-FLAG
421-0323
421-0187
420-9691
430-2600
410-1883
313-7054
420-9850
Roxio 10.2 DE
420-9334
A1994353
430-2955
410-2087
312-0811
420-8051
950-3337
993-3487
992-4500
950-9797
960-8710
412-0360
988-7707
988-0099
420-9518
330-0171
Posted Fri 29 May 09 @ 12:54 pm
I Can Post the Chat if you'd like!!
