Topic: adding sound efx
how do i add sound efx, i got a load of reggae samples, air horns, lasers etc and want to put them into in with the sound efx or loop sampler that comes already with vdj how do i di this. i also know that the vdj sound efx are exe files
Posted Tue 07 Oct 08 @ 1:13 pm
open sampler > select a number you want to use for a particular effect > right click on little bullseye > select load and go to the folder you have your samples and double click on file, this will load the file > when loaded, right click on bullseye again and select save, repeat process until you have completed loading your files.
