Topic: Problems with Cue Points with VDJ
Hi,
Dont know if theres a post on this already, Each time i cue a trax with cdj and timecode cd's, i set the first cue correctly, browes the trax abit then try to go back to my cue as i would with a regular cd.. well it never stays cued... or if i cue a trax then when am ready to start it up to make my mix, its never cued where i had it cued..
Anybody has the same issue?
Thanks
Posted Mon 06 Oct 08 @ 9:25 am
CidK just wanted you to know this is a hardware related issue, and you could of found your answer in the hardware forum. Anyway don't setup cue points with your player, set it up with in the software, you will see the visual cue point marker when you do that.
please do not double post
