Topic: Help needed with Vdj set up using serato
ok i have a problem i am setting up my serato box with vdj 5.1 i went in to the sound set up went to the config for the time code but when i do the test its at 0% and i do have every thing set up right. i watched the vids on youtube over and over but i get the same result.
thanks to everyone that may help me with this
Posted Mon 06 Oct 08 @ 7:48 am
Alright, enough of this blank spamming.....please desist...thank you
yes.. the timecode signal works and supposed to be at 100%;however , some users say it still works at 0% .i say try it and see what happens.
another question are you using tccd or tcv?
is it vdj timecodes or serato?
i have the sl1 AND the ttm57. ttm57 doest work with vdj period!! unless you rig it ( i have ran vdj flawlessly with the ttm57 by running my maya44usb into it and using as a regular mixer(i love it this way lol)).
the sl-1 CAN be used with vdj timecodes AND serato timecodes .
if you are using cds, then i would try both timecodes im sure u should be able to get 100% with one of em .
i use vdj 5.2 with both timecodes with no problem.
I wish you luck with this .report back if you can
I am using the TCCD and serato sl1 box. It works at 0% but after a while of playing its none responsive to what i do on the turntable.
(STOP WITH THE BLANK POSTS!!!!!!!!! Discobrian24
