im trying to use the stock effects that come with vdj 5.0.7, they show up in the list under the effects tab but there is no activate button for anything but the FlippinDouble effect (which works fine). Clicking on the TK Filter V2 or the vocals+ effect instantly closes the program. previously when i would click on the tk Filter V2 effect i would get an error message that the xml file would not load correctly (or something like that) but now it just crashes.
The .dll files in the appropriate folder, documents/virtualdj/plugins/soundeffects...and i did the directx updates that were mentioned in another thread, but still no luck. any ideas how to get these to work? do i need to download some sort of update or re-download the effects files from somewhere?
i have an HP pavilion with Vista, if you need more info on my computer spec let me know, im not sure what info you would need.
thanks!
thanks!
Posted Thu 02 Oct 08 @ 10:57 pm
Hi djgwantim, do register ur serial in ur profile n download to the latest version V5.2.1 and grab more goodies;)
Posted Thu 02 Oct 08 @ 11:08 pm
