Hello! I have virtual dj pro on my laptob. What is the best source or what equipment do I need to start dj-ing at parties and nightclubs? What do you recomend? I have regular dj equipment but i see everybody is going high tech now so i want to start using my laptob too. I have speakers, mixers, cd decks, and all equipment but do i need a sound card or what do i need to get started?
Posted Mon 29 Sep 08 @ 10:37 am
Well,
first of all you have to decide whether your want to go down the controller route, OR use your existing equipment you've got and go down the timecode route.
If you go with a controller I would op for the RMX, it is a native controller of VirtualDJ and has a built in soundcard.
If you go with the equipment you've already got the I would suggest getting yourself a ESI Maya44 usb soundcard. It's a good starter soundcard and it has the 4 inputs and 4 outputs you need for timecodes.
The timecodes can be downloaded from the site and burn on to a disc.
Posted Mon 29 Sep 08 @ 10:45 am
