hi guys,
anyone experiencing activation issues my vci will no longer longer work after 2 months use the config select does not light up green but red this then will not make my vci work
it a software issue i have tried fresh installs even trail demos even old 5.0 version still same problem
HELP !!!!!!!!!!!!!!!
Posted Sun 28 Sep 08 @ 4:15 pm
sorry guys was upset plus never used this area before . It seems the alien has locked me so i found this one he forgot .
to carlrose it just suddenly stopped cant understand why ive been using it for 2 months now
even on a totally different pc area house same thing.
Posted Mon 29 Sep 08 @ 9:00 am
SORTED IT !!!!!!!!!!!!!!!!!!!
ITS THE WEB CAM DRIVERS IT INTERFERES WITH THE CONECTION IN REMOTE MIDI ACTIVATION JUST UNINSTALL IT OR DRIVERS AND IT WORKS AS BEFORE.
TO ALL POD CASTERS AND WEBCAM USER SORRY CANT USE VDJ MIDI MAP IF HAVE WEB CAM
Posted Tue 30 Sep 08 @ 9:48 am
