Topic: VDJ Console vs VDJ Pro
What are all the differences between the VDJ edition that i got with my Hercules MK2 and the Pro edition? i was hoping there would be a chart somewhere with the differences and what more i will get if i upgrade buti cant seem to find one. anyone?
Posted Fri 26 Sep 08 @ 2:45 pm
actually the difference i think with vdj console and vdj pro is that with virtualdj you can have a time code where you can use the timecoded vynil. you can check it on the configure menu specifiically the audio set up and you will see that you cannot access the time coded and other sound set ups! some skins and effect that you can download cannot be used here at the site. anyway cheers brother were still ni 1 for mixing considering the features ang our sites!
