Good morning
Yesterday i went over to a frind to try and run TCV on his rmx (Limited verrsion of VDJ). We hooked up a normal turntable (old yamaha whit belt drive) with no pitch control. Run the Serato TCV. Worked just fine but the pitch keept on changing. We run auto config and just one TCV.
Should it be that way or is it the turntable that didn“t work like it should?
Posted Fri 26 Sep 08 @ 2:46 am
Try altering the Pitch Sensitivity in the timecode config
And you really must have Direct Drive turntables with pitch control.
Posted Fri 26 Sep 08 @ 7:20 am
