Hey is it possible for Virtual DJ to out put master in channel 1 and headphones in channel 2 rather than Master 1&2 and headphones 3&4?
Posted Thu 18 Sep 08 @ 3:29 am
do u have 2 soundcards? i take it you do in config, sound setup select the 2 soundcard option and in the drop down box at the bottom you can change the different conbinations
Posted Thu 18 Sep 08 @ 3:33 pm
I'm trying to run 1 sound card.
Its the novation Nio, which is supposed to be compatible according to the hardware section on this site but because its 2 in 4 out i cant get it to work.
Posted Thu 18 Sep 08 @ 6:43 pm
is there any options in that little drop down box in config -> sound setup that have it in there? as they are all the options that are available (which i know of)
Posted Fri 19 Sep 08 @ 3:17 pm
Nah checked that mate?
Any other ideas???
Any other ideas???
Posted Sat 20 Sep 08 @ 12:00 am
hey guys kind of new. how do i listen to a deck with ear plugs or headphones and have my speakers playing the other deck u know????????????
Posted Tue 30 Sep 08 @ 11:12 pm
Dear;
How can i work with headphones and my sound boxes with only one soundcard? I tried a lot but...nothing works.
Posted Wed 01 Oct 08 @ 3:25 pm
