Hi all, i just bought the a new DJ Console RMX and now using VDJ 5.2 demo.
Besides .mpg, .avi, .wmv, and quicktime, I cannot get VDJ to see .m2v, .mkv, or .vob when I highlight the directory folder (it's just blank). Has anyone try to come up wtih a solution for this?
also,
Which video cards works better on laptops, ATI or Nvidia? Currently I see static lines going across the screen on the TV and Monitor output. I think if i upgrade to a better video card it will fix it. Right now my video card is an old ATI 128 shared memory.
and
5.2 demo does not allow me to specify the 1-6 fx buttons other than showing that it is activated, if I upgrade to the pro version will this let me re-assigned them?
thanx for help.
also,
and
thanx for help.
Posted Mon 15 Sep 08 @ 10:43 pm
With regards to the file issue, you need to add the extensions on the codec tab, and point them to a relevant video decoder such as "Windows Media Video Decoder".
Then they will show up and be playable :)
Regards,
Scott
Regards,
Scott
Posted Tue 16 Sep 08 @ 11:21 am
