Jason,
At this time, you can only use one Denon DN-HS5500 in midi with VirtualDJ. As for the Korg Zero8, I'm not using it's internal soundcard nor am I doing timecodes. I'm using a Rme Fireface 400 for a soundcard. I do use the Korg Zero8 in midi. I've assigned some midi controls on it to make it easier for me. I only touch my laptop for searches, Everything else I do with the Korg Zero8 and the Denon DN-HS5500.
Posted Fri 26 Sep 08 @ 9:34 am
Thx. I was pretty sure I already knew the answer. Is there a big difference between your sound card, and my maya44. Have you had any luck using your korgs midi for the sampler section of cue. I tried programing it, using my korg and my akai mpk49. not a lot of luck.
Posted Sat 27 Sep 08 @ 1:52 pm
Shrunk my Vista Drive on my Toshiba laptop, installed XP on the new partition, reinstalled VDJ on the XP OS. First indications are everything is 100% better. No lockups, the platter can spin without losing MIDI connection. While not perfect yet, it is definitely usable, whereas I did not feel good about my setup in Vista at all.
Thanks,
Taipanic
/VDJ 5.2
/Toshiba Satellite
/AMD Turion X64 1.8ghz
/2 gig RAM
/Windows Vista/Windows XP
/Denon DN-HS5500 CD Firmware 1200
Thanks,
Taipanic
/VDJ 5.2
/Toshiba Satellite
/2 gig RAM
Posted Sun 28 Sep 08 @ 1:55 pm
Dj_john24 wrote :
Hi,
Did the new version of VirtualDJ (Ver5.2.1) fix the problem with the spinning platter on the Denon DN-HS5500's ????
Posted Mon 01 Feb 16 @ 10:42 am
Do you realize that this thread is from 2008, and you are asking a question about version 5?
Posted Mon 01 Feb 16 @ 5:30 pm
Along this same thread for the current day...
Has anyone used the 5500 with version 8? Can v8 support two players to work within one unit (it took a lot of work with v7)?
If so how does it perform? I have two of the 5500's but have not used them with v8 yet (I currently use the Denon 3900's).
Maybe one of these days I'll give them a try.
Posted Mon 01 Feb 16 @ 6:28 pm
If your talking about using them in midi mode, don't even waste your time and more then likely its never gonna get fixed, which I was told in so many words.
The way the midi is sent from the platter is the problem. Not that VDJ couldn't fix it but I guess its more hassle then it worth.
So yeah it sounds and plays like doo doo, don't waste your time.
Time code yes, midi no.
Posted Mon 01 Feb 16 @ 8:28 pm
I recently tried using just one HS5500 with VDJ 8....
Although not perfect, playing one track through the audio interface using MIDI control is, well, fair/reasonable.
As soon as you introduce the second layer (deck) though, it all goes pear shaped.
Posted Mon 01 Feb 16 @ 9:13 pm
