On my left deck the timecode quality is fine, and it's at 100%. Also no distortions or anything.
On my right deck timecode quality is 0% constantly, and randomly distorts and skips. How would i fix this... is it a bad vinyl?
Posted Sat 13 Sep 08 @ 2:12 pm
what happens if you copy the settings from deck 1 to deck 2
And does deck 2 show TWO waves, one green and one red?
Some used turntables end up sending out a mono signal
Posted Sun 14 Sep 08 @ 6:19 am
To check the vinyl, just swap them around ;)
Also have you got the same type/age needles on both decks. The needles have a big affect on the signal aswell.
Posted Sun 14 Sep 08 @ 7:11 am
I got problems with 0% signal on my timecodes (1st time setup)
I got 2x numark tt-500 and TCV3-UK... using my internal soundcard (5.1) + a soundblaster audigy 2.. I get signal from the turntables, but it's showing 0% anyway..
I haven't got my new pickups yet, so i'm using the standards that came along with the turntables atm...
What do you think? Is it the pickups, cables, soundcard or what?
Posted Sat 20 Sep 08 @ 4:19 pm
