I just been playing on my mates PCDJ VJ setup and I been thinking this.
Since PCDJ VJ has been developed in partnership with VirtualDJ. I was wondering if the Database structure and the way it reads the files the same as how VirtaulDJ does it, or is it totally different.
Basically I want to know, will PCDJ VJ will read my files and DB on my External harddrive.
Posted Sat 13 Sep 08 @ 10:04 am
try taking copy of your xml file across with it jim and see if that works... just a guess
Posted Sat 13 Sep 08 @ 10:19 am
Hi Jim
It does, you just have to rename the xml so PCDJ recognises it as its own.
Posted Sat 13 Sep 08 @ 11:13 am
hi guys, this is my first post here.i have purchased pcdjfx which i will be using for all my gigs,the question is i have been messing around with it on my desktop loading my 20,000 plus karaoke and 30,000 plus audio tracks to get the feel of it but what i need to know is can i transfer the db over to the laptop i will be using to gig with so i dont need to do it all over again? if so how do i identify which folder it is hope someone can help regards paul hull uk
Posted Mon 02 Mar 09 @ 5:50 am
Posted Mon 02 Mar 09 @ 7:08 am
