Hi there, I am looking into purchasing an new Vista laptop, and I was wondering if Numark Cue works with Windows Vista 64-bit. I am currently running Vista Home Basic 32-bit with no problems. Is anyone running 64-bit?
Thanks
Jordan
Thanks
Jordan
Posted Tue 09 Sep 08 @ 5:44 pm
Yes but alot of hardware currently does not what would you be using with it?
Posted Fri 19 Sep 08 @ 6:12 pm
Thanks
Jordan
Thanks
Jordan
I'm using native VDJ 5.2.1 with Vista Ultimate 64-bit.
It installs as a 32-bit compatible application and runs without a glitch. My main reason for utilizing 64-bit is so that the OS would recognize 4+GB of memory on my system.
I'm using Denon HC-4500 & HS-5500 hardware/sound cards and both operate fine using the Denon ASIO driver utility.
Good luck!
-=Woody=-
Posted Sat 20 Sep 08 @ 4:20 pm
if you upgrade your 32bit vista to service pack 1, it will recognize and use 4gb of ram..................
Posted Sat 20 Sep 08 @ 6:55 pm
Im having this same problem with Vista 64-bit. I keep getting "windows could not find driver software for your device" Is there somewhere i can get a driver to fix this?
Posted Fri 05 Dec 08 @ 6:16 pm
I don't think there are 64-bit drivers for the VV interface, I could be wrong though
Posted Sat 06 Dec 08 @ 3:44 am
