I wish to use my DJ console with an external mixer but cannot find the correct configuration in VDJ to set this up.
I have outputs 1+2 plugged into channel 1 on my mixer and outputs 3+4 going to channel 2. In config i select 'external mixer' and have tried both DJ Console + 2 sounds card in the Sound Card option. Each time the channel are not correctly split and the crossfader on the DJ console still controls the fade.
Posted Tue 09 Sep 08 @ 12:45 pm
hi baseman
these are the settings i use with a ext mixer
hope it helps aubs
hope it helps aubs
Posted Tue 09 Sep 08 @ 2:07 pm
Perfect aubs123, thanks. All working fine now :)
Posted Tue 09 Sep 08 @ 4:22 pm
