Topic: Dj control Mp3
Hello i recently bought a Dj Control Mp3 it works really good so far
Do you think it is good enough or should I have bought the Mk2???
Posted Mon 08 Sep 08 @ 11:06 pm
I use to have the total control a well. Honestly I do not see or hear any difference between the 2. They both work well with VDJ.
Apparent differences between dj console mp3 vs herc mk2 is that the latter is also a soundcard;)
When I bought my mp3 control I found out that the main difference was that the mk2 has a sound card built in. As I was pleased with my old sound card, I didn't need the mk II. I think that I saved allot of money on this. I'm happy with the controller, it works as I thought it would :)
This is, I think the only difference...The controller itself is the same, but the MK2 includes the soundcard, as was mentioned. If you already had a soundcard, you didn't need the MK2 ;)
i have numark djio soundcard which seems ta do the job.thinking of purchashing a mk2.is the soundcard beter.and powered or passive speakers ?
Another advantage that u can use the mk2 for timecodes usage and of course as controller opposed to the djio which also is a good card;)
would love to just use laptop and rmx but the screenfreeze bit has me scared dont want air on dancefloor lol.
also how does the timecodes work and what is the clip art,love theese forums so helpfull as no time with 4 sprats lol
Timecodes werk with the mk2 (mid-range soundcard) by connecting the TT or CD deck to the inputs of the units. TT (phono) CD/Digital (line).. Then from the outputs goes into ur external mixer. Example below;)
