Hey guys, I have this problem. Im trying to analyse the BPM's on my music folder. When dloing so it will start then a few songs in it will freeze ? never had this problem before. Help ?
Posted Thu 04 Sep 08 @ 6:24 pm
I'm having the same problem. I use Flac files so I thought that maybe the issue so I never inquired about it. When I load a song to get analzyed by VDJ it will show that it's loaded in the software but on my Denon HC 4500 it remains at "loading" and freezes the software.
Is anyone else having this issue?. I've only been seeing this "freezing" over the last two updates.
I'm hoping it's a bug in the new updates.
Posted Sun 07 Sep 08 @ 5:00 pm
This is messed up I never had this problem. It started when i formated my laptop and re-instaled VDJ...
Posted Sun 07 Sep 08 @ 5:06 pm
Can Anyone help with this???? Still waiting, I have tried everything still nothing.
Posted Tue 09 Sep 08 @ 5:09 pm
Can you explain the procedure that you are using?
Posted Tue 09 Sep 08 @ 7:45 pm
Ok well im trying to analyse my music folder. I right clink on the music folder then click on analyse then any music. I t will start but then freeze after 1 or 2 songs. Am i doing somthing wrong ?
Posted Tue 09 Sep 08 @ 8:02 pm
Also adding to that, For the ones that are analysed everytime i start up to program it seems that the bpm's are not been saved ? i have to redo it
Posted Tue 09 Sep 08 @ 8:08 pm
As a test, try selecting a few songs in the browser, right-click, then select analyze>techno/house (depending on the version), and see how it responds. What version are you using, BTW?
Posted Tue 09 Sep 08 @ 8:31 pm
Tried that, im using 4.2
Posted Wed 10 Sep 08 @ 6:01 am
What were the results?
Posted Fri 12 Sep 08 @ 4:59 pm
same thing it will analyse a few songs then freeze
Posted Fri 12 Sep 08 @ 8:13 pm
Does the process always freeze on the same track? If so, that track may be corrupt.
Posted Sun 14 Sep 08 @ 8:08 pm
Ok thanks for the help...... But im still stuck with this problem.
Posted Mon 15 Sep 08 @ 8:31 pm
If you are using a cracked version, you can expect all sorts of unusual errors. If you are using a valid copy, you should register here.
Good luck with your issue.
Posted Wed 17 Sep 08 @ 3:55 pm
