Topic: Strange noise on sliders
Hi I am new to this forum so I don’t know if this has been answered before but when I am mixing on my laptop and I have the slider say for deck 1 down and bring the bass knob down as well deck 2 is playing fine.
But when I then bring the slider for deck 1 up or the bass knob I get a strange noise much like well the only way to describe it is like a FRAT the slower I bring them up the more noticeable it is. It is the same on deck 2 if deck 1 is playing at the time. Is this a common fault or have set it up wrong.
Posted Tue 02 Sep 08 @ 5:02 am
Untick the safe mode in the performances setting in VDJ config. Set auto to latency.
Thanks a lot no more noise on sliders or the knobs did you mean set the latency to auto? But I do have another problem don’t know if you are able to help some times if I minimize VDJ or start from my desktop icon on my laptop it shuts down my laptop and turns it off it is probably another setting problem or the end user me lol.
Hi badbeat, yes set latency to auto.
What version are u using n what OS n what is ur system specs?
Hi SpinnaJ I have got VDJ version 5.2 and Windows Vista Home Premium with Intel core 2 duo 1.66Mhz 2.00 Gb ram
Try this. uninstalled n reinstalled the trial on admin. Im not so well versed on Vista OS. It might help tho. N this shutting down i assume on the default skin?
Hi can anyone help I am just starting out mixing but do not have a mixer yet can anyone suggest a good but cheap mixer to start out with that works with VDJ. I am running VDJ version 5.2 and Windows Vista Home Premium with Intel core 2 duo 1.66Mhz 2.00 Gb ram
Please ignore last message put it in the wrong place
