Hello.
I´ve just bought an Hercules Dj console rmx that comes with the virtual dj version created specially for the console but i have a question...
Since this version doesn´t record what i´m playing, i would like to use it with my initial version of the virtual dj, the 4.3.r12 but i can´t seem to be able to connect the console to this version of the virtual dj...
Can anyone help me ?
Thanks
Thanks
Posted Mon 01 Sep 08 @ 10:41 am
That version of VirtualDJ won't recognize the RMX.
You have to have VirtualDJ 5.rev7 and above for the controller to work. Try downloading the demo (5.2) and see.
Posted Mon 01 Sep 08 @ 10:58 am
Í´ll try that !
Thanks for your help !!
Posted Mon 01 Sep 08 @ 11:06 am
I recently purchased the DJ console RMX and after I install the software from a CD-ROM, I keep getting the error message
"The Hercules DJ series drivers found on your system is older than expected please reinstall the Hercules driver package"
Can Not install DJ console RMX drive package, version 3.1 on windows 7 operating system.
Can anyone help.
Can anyone help.
Posted Tue 15 Jun 10 @ 10:17 am
Then you should download the latest driver from the support site:
http://ts.hercules.com/eng/index.php?pg=view_files&gid=17&fid=62&pid=215&cid=1
Posted Tue 15 Jun 10 @ 2:05 pm
i just bought the hercules rmx , i put in ma cdrom into the computer, and it wont pop up. ive tryed lookin in my computer but still nothiin its as if the computer isnt readin the disk,. i got windows 7 can anyone help ?
Posted Thu 05 Aug 10 @ 5:22 pm
