Hi! evryone! I've just bought my MACBOOK & My U46 MKII, dowload Virtual DJ 5.2 for MAC but I've a Problem T_T I can't config my TimeCodes (I've No Signal).
This is my configuration :
Can you help Me Plz T_T
Thanks.
FvD -_'
Thanks.
FvD -_'
Posted Mon 01 Sep 08 @ 9:15 am
Hi DJ Kuzuki, You need to add it as an aggregate devices for ur mac osx. U can still use as a normal soundcard without timescodes capability.
Read this thread for some info on how to set up.
On the current version, only numark virtual vinyl interface and herc rmx can be used for timescodes. Hopefully this will be resolved in future updates. Thanks for your understanding;)
Posted Mon 01 Sep 08 @ 11:03 am
Thanks T_T so I can't use My TimeCode for the moment with my U46 MKII right?...
kuso... when the update will fine? ^^
Posted Mon 01 Sep 08 @ 1:07 pm
Yes i afraid to tell u so:(
But be patient on this man, i sure this will be resolved;)
Posted Mon 01 Sep 08 @ 1:16 pm
I hope soon too ^^ for the moment I must to use Boot camp for the moment... kuso -_-'
Posted Mon 01 Sep 08 @ 2:33 pm
