As my title says, VDJ is displaying when I load it... When it loads it comes up the Loading Dialogue Box and then it says, it need a Higher Resolution, Then I click ok... It loads and then nothing... VDJ just stays in my task tray or whatever it is...
I am new to this... I am on trial too.. can someone help me please?
Posted Tue 19 Aug 08 @ 6:31 am
The default resolution of all default distributed skins are 1024x768, you need to run in that minimum resolution.
What resolution is your system set for ?
Posted Tue 19 Aug 08 @ 8:32 am
I maneged to get in! =)
Posted Tue 19 Aug 08 @ 10:41 am
