Hi.. couple of weeks iv bought the rmx midi controller with VDJ limited edition.. works fine with 1/4 cables... then i installed the VDJ pro 5.07 then i tried to connect the hercules rmx to my PA system with 1/4 jacks.... and the sound was really low.. LOW LOW!....
any ideas?... tnx :S
Posted Mon 18 Aug 08 @ 5:55 pm
install 5.2 and have all RMX drivers upto date, should see a marked improvement, but understand some have had problems with 5.2 and reverted back to 5.1, you will have to re scan all your files when updating to 5.2
Posted Wed 20 Aug 08 @ 6:51 pm
Also make sure you have the newest drivers from Hercules also. There was a major difference in volumes between the older and newer drivers.....
Posted Wed 20 Aug 08 @ 6:55 pm
nope!.. still the same problem.
Posted Wed 20 Aug 08 @ 9:02 pm
