Hi
I'm having some sound issues. I have the Numark tt 200's, numark dm3002x mixer, maya 44, gateway laptop w/ windows vista.
Is there anything I can get for the sound quality? When i use the regular vinyl set up everything is fine. but when I try to go digital the sound from the mixer is terrible. any suggestions will be greatly appreciated.
Posted Fri 15 Aug 08 @ 1:57 pm
there are many settings for TCV in VDJ. check the forum, you have some guides too.
Posted Tue 19 Aug 08 @ 2:32 pm
I read in a leafet that came with my Numark DM950 USB that laptops can make the sound hum and distort, this is apently because the way thelaptop is grounded, try running on batteries and see if this sorts it, if it does you can remove the earth wire from your laptop plug but this is dangerous and u should know what your doing but hope it sorts it, my laptop is alrite thankfully!
Posted Wed 20 Aug 08 @ 7:02 am
