Hello,
when i plug my iPod on my Hercules RMX Input 1/2 and set the "source 1" button to on i can't hear anything.
What setting i have to make?
My current sound setting:
Inputs: None (tried also "Single Timecode" and "Timecodes")
Outputs: Headphone
Soundcard: 4 out card
Driver 1: Hercules Dj Console RMX
Outputs: Headphone
Posted Thu 14 Aug 08 @ 2:00 pm
Nobody has an idea? I only want to use the Inputs of my rmx with VDJ Pro 5.2 for Mac.
Posted Sun 17 Aug 08 @ 11:32 am
When u pressed the source 1 button, need to adjust the volume from the ipod n herc control panel etc. U bypass it n it will not use VDJ mp3 tracks. Once u re-pressed the source button, it will return to the computer tracks. Also make sure it is in line not phono.
I use vinyl when bypass n i sure the ipod werk about more or less the same way. Hope that helps.
Posted Mon 18 Aug 08 @ 5:06 am
Solved :)
Posted Mon 18 Aug 08 @ 2:32 pm
Great.. glad u get it right;)
Posted Mon 18 Aug 08 @ 2:41 pm
It was an consequence of the "Error in the sound driver"-Problem. But thanks for your pain ;)
Posted Mon 18 Aug 08 @ 3:06 pm
