I was just having to same problem but found the fix for it. When you go to "config" and your under the video option make sure the "use hardware acceleration" option is checked under video output. Hope this works the same for you.
Posted Thu 22 Jul 10 @ 2:01 am
I have exactly the same problem with my pro edition for mac. When I select master+mic or line the program keeps waiting.
I can't find "use hardware acceleration".
Posted Tue 17 Aug 10 @ 8:10 am
same problem. i must use vdj6 for a line-in problem with vdj7 anad macbook.
when i start record, or broadcast, still this "waiting to start". i tryed everytning. I haver no "hardware acceleration" box in video option.
Posted Sun 12 Dec 10 @ 3:29 am
This was mentioned a while back in the video threads i think.if you have it set to video recording you need to activate the video screen,right cliking on the output screen....
Posted Sun 12 Dec 10 @ 10:21 am
i don't found anything of similar :(
anyway i tryed to turn on any option of video, with same result: always this "waiting to start" :(
Posted Sun 12 Dec 10 @ 2:02 pm
find!!!!.....remove and attac USB multipple time, when you're sure, your setings it's OK!!!!!.... TRY THIS "for my now i'm OK"
Posted Wed 01 Feb 12 @ 9:47 pm
not the same for the video......but try enyway
Posted Wed 01 Feb 12 @ 9:48 pm
Thread is too old to be alive.
Thread locked
Posted Wed 01 Feb 12 @ 11:34 pm
