Hello gang...looking for some assitance in properly setting up VDJ v5.1 with my Numark CM 200 USB Mixer.
I can't seem to figure out how to set up the configuration of VDJ so that I can play each deck to a seperate channel in my USB Mixer.
The Numark CM 200 USB Mixer has two USB connections so that you can run a USB cable to each channel.
I am hoping that I can run my right deck to it's own channel and the same for the left deck through my USB cables however, I cannot figure out how to set it up properly in the CONFIG.
I currently am running it as:
Inputs: None
Outputs: External Mixer
Sound Card(s): 2 Cards
I have tried many other configurations however....I keep getting the Left Deck and Right Deck playing in the same channel.
Any assistance is greatly appreciated.
Inputs: None
Posted Fri 25 Jul 08 @ 9:06 pm
Use the DMX01 option that comes up in the soundcard drop-down. It is the same soundcard mixer design that is in the 200. Then you should be good.
If you want to use the 2 card option then you simply select the first Audio USB Card in the drop-down list for card 1, then for card 2 select the second Audio USB Card option in the drop-down. Also, double check the back of the mixer and make sure both the switches are set for the respective channels 3 and 4 and NOT Master or Record.
I have that mixer and it's great once setup.
Posted Sat 26 Jul 08 @ 1:55 am
Thank you cstoll for the response however, in the "Sound card(s)" dropdown option within the config, I do not have a "DMX01" option to choose from. The only options I have to select are:
- Mono Seperated
- 2 Cards
- 4.1 Card
- Asio Driver
Yes, the back of the mixer is set as:
- USB A = Channel 3
- USB B = Channel 4
- Mono Seperated
- 2 Cards
- 4.1 Card
- Asio Driver
- USB A = Channel 3
- USB B = Channel 4
Posted Sat 26 Jul 08 @ 8:32 am
Also, in response to your second paragraph...
If I have the "2 Cards" selected in the drop-down for "Sound card(s)", I get the following as my options within the drop-down below it:
- Sound Card
+ Primary Sound Card
+ Speaker (2- USB Audio CODEC)
+ Speakers (Conexant High Definition SmartAudio
+ Digital Output Device (HDMI) (2- High Definition)
+ Speakers (USB Audio CODEC)
+ SPDIF Interface (Conexant High Definition SmartAudio
And I have the same drop-down options within the "Second card" as well.
Still can't seem to get this right.
Thank you for your assistance here and hopefully I can get this booger up and running soon.
- Sound Card
Posted Sat 26 Jul 08 @ 8:59 am
What version is this? It's ODD that it isn't seeing the DMX01 option ... but anyhow...
OK, I just had the reference wrong for the drop-down options --
Output - External Mixer
Soundcards - 2 cards
Sound card - Speakers (USB Audio CODEC) [The 5th one in the list - this should be left (Chan 3)]
Second card - Speakers (2- USB Audio CODEC) [The 2nd one in the list - this should be right (Chan 4)]
And if I got them backwards then use the output channel drop down to flip them.
Posted Sat 26 Jul 08 @ 9:56 am
That did it my friend. ;-)
Thank you so much for your patience and assistance in helping me get this right!
Posted Sat 26 Jul 08 @ 11:56 am
I'm having similar issues with my M-Audio Fast Track Pro. I choose the ASIO driver. I point Deck 1 to 1&2 and Deck 2 to 3&4 but only channel 1 is playing. If I move Deck 2 to 1&2 as well, I get both decks on the same channel. What is the correct configuration for an ASIO external device?
Posted Fri 23 Sep 16 @ 8:24 pm
I'm sorry, but what ever issue you are having now, has nothing to do with this 9 year old thread. Please start you own thread, thank you.
Locked for being old by AMAHM
Posted Fri 23 Sep 16 @ 9:16 pm
