After singing my new Vista laptop praises last week, I've been noticing that something is not quite right, with the CPU usage. When VirtualDJ is idle the CPU meter on the skin I use is fluctuates all over the place from 3% to 35%. Is this right, and are these meters accurate.
When I play, with my RMX or maya/TCV's the CPU usage fluctuates alot more 7% to 45% and when I load up the other deck it sometimes reaches 70%, to me this is not right and too high. And these are just mp3 files I'm loading
At the moment I'm running the DPC latency checker to see it I've got any conflict any where. Everything seems fine, got green and yellow bar's on the graph. Also I've done all the usually things, like turning off UAC, sidebar Wifi and all that.
I'm abit concerned. Any ideas.
Posted Mon 21 Jul 08 @ 12:07 pm
Or is this just a Vista thing, with using more resources than XP.
Posted Mon 21 Jul 08 @ 1:16 pm
Vista does use more resources than XP because there's more services active. Vista has a lot going on in the background, some examples include the Volume Shadow Copy and Windows Search services. I'm not sure that your CPU usage when loading a track is too out of the ordinary, Virtual DJ will load a track as fast as it can without occupying 100% resources, speed load may play a part in that but I would think seeing upto 70% usage there is fine. Whether you have a 1 Ghz Celeron or a 3 Ghz C2D, it's possible there will be the same CPU usage, the difference is the C2D would be a lot faster.
Do you use Master Tempo or have any actively loaded antivirus software?
Posted Mon 21 Jul 08 @ 1:31 pm
I do use master tempo sometimes, and I have the free version of AGV on this laptop, (basic cover) but even when I turn this off in the start up the CPU usage is still the same.
Posted Mon 21 Jul 08 @ 1:39 pm
Generally when you turn off your antivirus you are only turning off the control centre. Most AV programs are a kernel service and can only be disabled in the services section of msconfig or by executing services.msc which will then require a restart.
However, I'm not sure whether it is the AV program causing these spikes, or another service or program. Unfortunately there's not a way in Windows to make a log of all the currently running programs and services which makes this sort of thing easier to diagnose.
Your usage does seem quite high but I can't compare it to my TCV setup at the moment as I'm away from my student house for a while :(
Do the spikes occur regardless of wdm and asio?
Posted Mon 21 Jul 08 @ 1:52 pm
I always use Asio, whether with Timecodes or not. Sound quality is this mode is alot better IMO, but usage is high in both modes. I did try turning my AV of in msconfig.
Posted Mon 21 Jul 08 @ 2:00 pm
Press the "Windows Key + R", type "cmd" and press enter. Type the following commands and press enter (everything is without quotes):
"cd desktop"
"tasklist>tasklist.txt"
"sc query>services.txt"
This will create 2 files on your Desktop, tasklist.txt and services.txt
If you can post the information of these two files it may be easier to help see which process(es) may be working when they need not be.
Edit: Alternatively, you can watch where your CPU time is being spent. Load up Virtual DJ and leave it idle. Press "Ctrl + Shift + Escape", click "Show processes from all users" and confirm any UAC dialogues. Now, sort the processes by CPU so that it's in descending order, and watch which processes and up causing the spike which you may not have expected.
"cd desktop"
Posted Mon 21 Jul 08 @ 2:10 pm
I'll do that mate tomorrow, I'm on the dreaded not shift now, bit when I get up I'll have a go.
Posted Mon 21 Jul 08 @ 4:15 pm
@Anderw, managered to get them list for you
Tasklist
System Idle Process 0 Services 0 24 K
System 4 Services 0 13,796 K
smss.exe 532 Services 0 560 K
csrss.exe 616 Services 0 4,076 K
wininit.exe 668 Services 0 3,508 K
csrss.exe 680 Console 1 7,020 K
services.exe 720 Services 0 5,928 K
lsass.exe 744 Services 0 1,576 K
lsm.exe 764 Services 0 3,164 K
svchost.exe 928 Services 0 5,968 K
winlogon.exe 960 Console 1 4,068 K
svchost.exe 1028 Services 0 5,232 K
svchost.exe 1072 Services 0 15,160 K
svchost.exe 1132 Services 0 10,972 K
svchost.exe 1164 Services 0 61,456 K
svchost.exe 1184 Services 0 32,984 K
audiodg.exe 1264 Services 0 11,152 K
SLsvc.exe 1292 Services 0 8,744 K
svchost.exe 1328 Services 0 8,736 K
svchost.exe 1432 Services 0 10,068 K
spoolsv.exe 1632 Services 0 7,172 K
svchost.exe 1676 Services 0 9,660 K
ALaunchSvc.exe 2024 Services 0 4,468 K
taskeng.exe 400 Console 1 8,960 K
dwm.exe 580 Console 1 53,520 K
explorer.exe 804 Console 1 37,656 K
avgwdsvc.exe 1656 Services 0 2,120 K
eDSService.exe 1780 Services 0 3,344 K
eLockServ.exe 2152 Services 0 4,592 K
eNet Service.exe 2284 Services 0 4,800 K
HerculesDJControlMP3.EXE 2404 Services 0 4,012 K
IAANTmon.exe 2520 Services 0 4,688 K
LSSrvc.exe 2596 Services 0 2,844 K
SynTPEnh.exe 2668 Console 1 5,744 K
MobilityService.exe 2716 Services 0 4,520 K
RtHDVCpl.exe 2740 Console 1 6,792 K
svchost.exe 2816 Services 0 4,444 K
QtZgAcer.EXE 2828 Console 1 7,316 K
RichVideo.exe 2860 Services 0 3,448 K
IAAnotif.exe 3012 Console 1 5,836 K
avgtray.exe 3068 Console 1 5,288 K
rundll32.exe 3112 Console 1 5,112 K
svchost.exe 3164 Services 0 1,840 K
SearchIndexer.exe 3196 Services 0 15,860 K
HDJSeriesCPL.exe 3316 Console 1 6,876 K
PMVService.exe 3336 Console 1 5,956 K
rundll32.exe 3460 Console 1 6,144 K
rundll32.exe 3504 Console 1 3,112 K
XAudio.exe 3576 Services 0 2,048 K
eDSLoader.exe 3688 Console 1 5,928 K
eRecoveryService.exe 3696 Services 0 5,320 K
eAudio.exe 3716 Console 1 6,224 K
capuserv.exe 3872 Services 0 4,172 K
ePowerSvc.exe 3948 Services 0 5,676 K
WmiPrvSE.exe 2308 Services 0 5,320 K
sidebar.exe 2612 Console 1 7,520 K
unsecapp.exe 2604 Services 0 3,632 K
WmiPrvSE.exe 2852 Services 0 6,652 K
RtkBtMnt.exe 2836 Console 1 4,780 K
avgrsx.exe 2932 Services 0 54,036 K
avgemc.exe 3368 Services 0 1,348 K
RCHelper.exe 3040 Console 1 7,552 K
firefox.exe 740 Console 1 66,612 K
taskeng.exe 1944 Services 0 3,960 K
taskeng.exe 3644 Services 0 4,016 K
cmd.exe 1748 Console 1 2,056 K
tasklist.exe 2240 Console 1 4,684 K
Services
SERVICE_NAME: AeLookupSvc
DISPLAY_NAME: Application Experience
TYPE : 20 WIN32_SHARE_PROCESS
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
WIN32_EXIT_CODE : 0 (0x0)
SERVICE_EXIT_CODE : 0 (0x0)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: ALaunchService
DISPLAY_NAME: ALaunch Service
TYPE : 110 WIN32_OWN_PROCESS (interactive)
STATE : 4 RUNNING
(STOPPABLE, PAUSABLE, ACCEPTS_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: AudioEndpointBuilder
DISPLAY_NAME: Windows Audio Endpoint Builder
STATE : 4 RUNNING
(STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Audiosrv
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: avg8emc
DISPLAY_NAME: AVG Free8 E-mail Scanner
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: avg8wd
DISPLAY_NAME: AVG Free8 WatchDog
TYPE : 10 WIN32_OWN_PROCESS
STATE : 4 RUNNING
(NOT_STOPPABLE, NOT_PAUSABLE, ACCEPTS_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: BFE
DISPLAY_NAME: Base Filtering Engine
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: BITS
DISPLAY_NAME: Background Intelligent Transfer Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: CryptSvc
DISPLAY_NAME: Cryptographic Services
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: DcomLaunch
DISPLAY_NAME: DCOM Server Process Launcher
STATE : 4 RUNNING
(NOT_STOPPABLE, NOT_PAUSABLE, IGNORES_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Dhcp
DISPLAY_NAME: DHCP Client
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Dnscache
DISPLAY_NAME: DNS Client
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: DPS
DISPLAY_NAME: Diagnostic Policy Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: EapHost
DISPLAY_NAME: Extensible Authentication Protocol
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: eDataSecurity Service
DISPLAY_NAME: eDataSecurity Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: eLockService
DISPLAY_NAME: eLock Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: EMDMgmt
DISPLAY_NAME: ReadyBoost
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: eNet Service
DISPLAY_NAME: eNet Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: eRecoveryService
DISPLAY_NAME: eRecovery Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: eSettingsService
DISPLAY_NAME: eSettings Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Eventlog
DISPLAY_NAME: Windows Event Log
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: EventSystem
DISPLAY_NAME: COM+ Event System
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: gpsvc
DISPLAY_NAME: Group Policy Client
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: HerculesDJControlMP3
DISPLAY_NAME: Hercules DJ Control MP3
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: hidserv
DISPLAY_NAME: Human Interface Device Access
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: IAANTMON
DISPLAY_NAME: Intel(R) Matrix Storage Event Monitor
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: IKEEXT
DISPLAY_NAME: IKE and AuthIP IPsec Keying Modules
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: iphlpsvc
DISPLAY_NAME: IP Helper
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: KeyIso
DISPLAY_NAME: CNG Key Isolation
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: KtmRm
DISPLAY_NAME: KtmRm for Distributed Transaction Coordinator
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: LanmanServer
DISPLAY_NAME: Server
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: LanmanWorkstation
DISPLAY_NAME: Workstation
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: LightScribeService
DISPLAY_NAME: LightScribeService Direct Disc Labeling Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: lmhosts
DISPLAY_NAME: TCP/IP NetBIOS Helper
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: MMCSS
DISPLAY_NAME: Multimedia Class Scheduler
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: MobilityService
DISPLAY_NAME: MobilityService
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: MpsSvc
DISPLAY_NAME: Windows Firewall
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Netman
DISPLAY_NAME: Network Connections
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: netprofm
DISPLAY_NAME: Network List Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: NlaSvc
DISPLAY_NAME: Network Location Awareness
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: nsi
DISPLAY_NAME: Network Store Interface Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: PcaSvc
DISPLAY_NAME: Program Compatibility Assistant Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: PlugPlay
DISPLAY_NAME: Plug and Play
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: PolicyAgent
DISPLAY_NAME: IPsec Policy Agent
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: ProfSvc
DISPLAY_NAME: User Profile Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: RichVideo
DISPLAY_NAME: Cyberlink RichVideo Service(CRVS)
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: RpcSs
DISPLAY_NAME: Remote Procedure Call (RPC)
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: SamSs
DISPLAY_NAME: Security Accounts Manager
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Schedule
DISPLAY_NAME: Task Scheduler
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: seclogon
DISPLAY_NAME: Secondary Logon
STATE : 4 RUNNING
(STOPPABLE, PAUSABLE, IGNORES_SHUTDOWN)
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: SENS
DISPLAY_NAME: System Event Notification Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: ShellHWDetection
DISPLAY_NAME: Shell Hardware Detection
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: slsvc
DISPLAY_NAME: Software Licensing
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Spooler
DISPLAY_NAME: Print Spooler
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: SSDPSRV
DISPLAY_NAME: SSDP Discovery
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: SysMain
DISPLAY_NAME: Superfetch
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: TabletInputService
DISPLAY_NAME: Tablet PC Input Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: TermService
DISPLAY_NAME: Terminal Services
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Themes
DISPLAY_NAME: Themes
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: TrkWks
DISPLAY_NAME: Distributed Link Tracking Client
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: TrustedInstaller
DISPLAY_NAME: Windows Modules Installer
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: UxSms
DISPLAY_NAME: Desktop Window Manager Session Manager
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: W32Time
DISPLAY_NAME: Windows Time
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WdiSystemHost
DISPLAY_NAME: Diagnostic System Host
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WebClient
DISPLAY_NAME: WebClient
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WerSvc
DISPLAY_NAME: Windows Error Reporting Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WinDefend
DISPLAY_NAME: Windows Defender
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WinHttpAutoProxySvc
DISPLAY_NAME: WinHTTP Web Proxy Auto-Discovery Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Winmgmt
DISPLAY_NAME: Windows Management Instrumentation
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Wlansvc
DISPLAY_NAME: WLAN AutoConfig
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WMIService
DISPLAY_NAME: ePower Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WPDBusEnum
DISPLAY_NAME: Portable Device Enumerator Service
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: wscsvc
DISPLAY_NAME: Security Center
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: WSearch
DISPLAY_NAME: Windows Search
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: wuauserv
DISPLAY_NAME: Windows Update
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: XAudioService
DISPLAY_NAME: XAudioService
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Now that's going to take some reading for you, lol
Hope this helps you mate
Tasklist
Services
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: BFE
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: BITS
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: Dhcp
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: DPS
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: gpsvc
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: KtmRm
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: MMCSS
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: nsi
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: RpcSs
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: SamSs
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: SENS
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: slsvc
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
SERVICE_NAME: UxSms
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
STATE : 4 RUNNING
CHECKPOINT : 0x0
WAIT_HINT : 0x0
Posted Tue 22 Jul 08 @ 8:28 am
Also mate, this is the CPU usage when VirtualDJ is idle.
VirtualDJ.exe 5%
Perfmon.exe 3%
taskmgr.exe 2%
svhost.exe(netsucs) 1%
dwn.exe 1%
All the rest use 0%
Posted Tue 22 Jul 08 @ 8:47 am
Thanks for posting the list, having had a quick look at it there is a lot of processes running which could safely be stopped and I haven't even got to the services yet! I'll have a more thorough look later and post back what I think, but for now I would advise for sure turning off that search indexing service! Windows Defender is another useful feature of Windows Vista but you probably don't want it running in the background whilst using Virtual DJ. Disabling Desktop Window Manager (DWM) whilst running Virtual DJ may also provide additional benefits, although you will temporarily lose Aero and the 3D Alt-Tab switching. AVG seems to like a lot of memory, avgrsx.exe in particular. If you are comfortable disabling your antivirus, you will may have to do it in msconfig's services tab rather than the startup one. Do make sure your power settings are set to "High Performance".
One thing which is interesting from your list (other than the number of applications Asus/Acer? seem to think consumers need to run) is that the Hercules console has two control panels "HDJSeriesCPL.exe" and "HerculesDJControlMP3.EXE". Do either need to be open once you've configured the settings you want to use?
You don't have to disable services and processes using msconfig (unless it's a kernel service like Antivirus and some Firewalls), another way is to create batch files which only close processes and services before you launch Virtual DJ and then open the program when you finish.
Here's an example of how to use the commandline (will need to run as admin) to turn off Windows Search and Defender for this session only:
SC STOP WSEARCH
SC STOP WINDEFEND
You can combine multiple commands like this in a textfile which must be saved with the file extension ".bat", this way you're only stopping processes and services on demand rather than permanently. This is useful for things like the Print Spooler or Web Client which you're probably not going to need whilst using Virtual DJ.
SC STOP WSEARCH
SC STOP WINDEFEND
Posted Tue 22 Jul 08 @ 9:52 am
I've notice this, last week, I would of thought, I needed "HDJSeriesCPL.exe" for my RMX but not "HerculesDJControlMP3.EXE" aswell, strange is that.
Thanks for the advice, I'll wait till you have had time and gone though the list more in depth and given me a list of services to turn off. Could you do me a mini guide on the steps I will have to go though to turn these services of I don't need please, is the msconfig route good enough.
once again thanks,
Posted Tue 22 Jul 08 @ 10:12 am
Update- Disables the HerculesDJControlMP3.EXE (on cstoll advice) and this has brought down the CPU usage a little, may have been a conflict there between the to 2 control panels.
Disable the Windows indexing search and Windows Defender in services. This has help aswell.
Posted Tue 22 Jul 08 @ 1:39 pm
I made a small .NET application last night which I'll upload if I clean it up a bit, it allows stopping processes from within it before launching Virtual DJ and then starting them up again afterwards. It also reports which programs have spent the most CPU time and Desktop Window Manager took up a large amount of time so you may consider turning that off.
From your list I came up with what I think are safe options to disable but maintain usability:
=== Should be OK to disable ===
DISPLAY_NAME: LightScribeService Direct Disc Labeling Service (if you never use Lightscribe to record DVD Labels)
DISPLAY_NAME: Print Spooler (if you don't need a printer)
SERVICE_NAME: UxSms
DISPLAY_NAME: Desktop Window Manager Session Manager (if you can live without Aero / 3D Desktop)
(If you want to go further, although best not to permanently disable, only per requirement from a batchfile:
Windows Defender, Windows Update, Security Center & Software Licensing, Distributed Link, SSDP,
WebClient, WlanAutoconfig {if wireless disabled})
=== Items which I'm not 100% sure on as other than AVG, most seem to be specific to your laptop ===
msconfig is a fairly nice way to disable services permanently because it tells you the date disabled, so you can easily revert back any changes which have left you with undesirable behaviour such as some applications not being able to use the internet. However, the eXXXXXX services seem to be specific to your laptop so I don't know how they are going to behave, therefore I would recommend only turning them off by a bat file. It's easy to make one, make a new text file and save it as "services.bat", then before you run it, right click on it and choose as administrator.
The contents of the file may look like this:
@echo off
sc stop "eDataSecurity Service"
sc stop RichVideo
etc
SERVICE_NAME: UxSms
@echo off
sc stop RichVideo
etc
Posted Wed 23 Jul 08 @ 10:01 am
Just repeating myself as i mentioned this prog many times before. ENDITALL its a free app. It shuts down services which are not required before you startup VDJ works on XP/Vista. Also you can taylor it to shut down other services you don't want.
Heres the link www.docsdownloads.com/enditall-1.htm
Posted Wed 23 Jul 08 @ 10:31 am
Andrew I can't thank you enough for the you've time spent on this, I like the idea of the .NET app you've created, if you could clean it it for me, so I could use it would be much appreciated mate.
@chriso thanks for the link mate, will have a look at that app when I get home.
Posted Wed 23 Jul 08 @ 10:44 am
@echo off
sc stop RichVideo
etc
@echo off
sc stop RichVideo
etc
I do I create this, Notepad?
Posted Wed 23 Jul 08 @ 11:37 am
Yep, any text editor you like. The important thing is that when you're saving it, for type choose "All Files (*.*)" and then add ".bat" at the end of the filename. You'll know if you've done it right because the logo once saved will look like a little cog on a screen instead of a notepad.
Posted Wed 23 Jul 08 @ 12:03 pm
Right mate, I'll give it ago later :)
Posted Wed 23 Jul 08 @ 12:05 pm
Andrew, good news I think, done as you instructed and everything has gone well. I've ran the program. Had a mix for 30 mins and the CPU usage now doesn't really go above 22% when I'm playing, which I'm pleased about.
The only time it spikes is when I load a track (which is to be expected) and then it only goes to just over 50%, as before it somethings hit 70%. Running on automix at the moment (to test it ) and it's set to play for just over a couple of hours, and again the CPU usage is lower in this mode, than it was before.
One thing, when I'm done with this neat little program how do I disable it, so I can run windows "normally"
Thanks mate.
Posted Thu 24 Jul 08 @ 10:19 am
