Hi
Just wondered if any VDJ fans have tried the Novation Nocturn controller. It looks promising and there has been some interest on other forums
http://www.novationmusic.com/products/midi_control/nocturn/
A
A
Posted Wed 16 Jul 08 @ 5:10 am
I have not tried it but it does look promising for a video crossfader plus some other functions. $149 at Guitar Center here in the US.
Posted Wed 16 Jul 08 @ 8:26 am
Got one yesterday. I thoroughly recommend it - great value at 69 quid (UKP). Build quality is excellent and it's really easy to set up, in fact midi has never been this straightforward, essentially it uses an application (light) which you have to load with VDJ to map the midi but it means you get as many controls as you like - the basic 17 controls can be reassigned a page at a time, I've got 4 pages on the go at the moment so I can do a lot more than I could with my old X-Session (Evolution). In fact the Automap software window can be resized to fit over the mixer part of VDJ so I've got a pretty good temporary skin to play with (I'll be sorting my custom skin out next week). I used it last night at work and after(!) and found it pretty easy to use once I remembered which pages I put the controls on. If you are after small and light but solid equipment (I use a laptop and a Numark DJIO) then this is a pretty good choice. Love it!
Prof
Prof
Posted Sat 19 Jul 08 @ 1:08 pm
I'm just got a Nocturn and am trying (unsuccessfully) to map it to Virtual DJ. Can anyone help?
Posted Sat 30 Aug 08 @ 7:44 am
I have same problem with mapping VDJ. I believe that is possible to change settings somehow in nocturne to have MIDI protocol.
Can anyone help?
Cheers,
Alexey
Can anyone help?
Cheers,
Alexey
Posted Fri 27 Nov 09 @ 5:38 am
Prof
hey man can u show me how to do it please?
Prof
Posted Sun 10 Jan 10 @ 2:17 pm
guys should be the same as any midi controller.
open up controller section.
see if your device is on top column,
then press button on device and map what you want it to do.
or just use simple midi and press desired button then agai map it to whatever you want,
remember take you time know what you want to do and map away
Posted Sun 10 Jan 10 @ 2:29 pm
It is still not working i have automap 3.4 and the nocturn evrything is working fine but virtual dj doesn't recognize my controller
Posted Fri 15 Jan 10 @ 11:12 pm
dont know this controller but have you got the latest drivers installed for the unit if so.
go to your mapping section.use the dropdown box to see if your controller is there.
just beside where it says simple mapper click on the book square and select which midi your device is the rescan for your controller.
when you see yours in the dropdown just push a button and map away
Posted Sat 16 Jan 10 @ 3:35 am
I cant even get VDJ 6 to recognize it.. how do you do that?? I click the rescan button but it doesnt fnd it... I even had VDJ freeze once while it was scanning...
Posted Wed 10 Feb 10 @ 12:17 pm
Still working on trying to get this to work. I see people on here have it working .... BUT HOW??
Posted Wed 10 Feb 10 @ 5:41 pm
Was struggling with mine at first too.. bought it wed and spent the greater part of yesterday messing with it and VDJ but i git it working! it was tricky at first.. the instructions are pretty much useless.. if you still need help let me know :)
Posted Fri 12 Mar 10 @ 6:36 pm
I am having issues with this still. could you provide a quick step by step for us?
Posted Thu 15 Apr 10 @ 5:42 pm
I am trying to get VDJ 6 on a MAC to recognize the aumap midi but nothing! It won't show up on the list!
Any help here guys? :)
Posted Sun 16 May 10 @ 12:29 pm
any luck anyone? setting up this nocturn with vdj is proving a complete nightmare. I can' figure it out!! arghhhh!
HELP! anyone who has managed it please just put up some clear instructions on how to do it. Please!
Posted Tue 25 May 10 @ 9:16 am
YES I NEED HELP!!! please
Posted Tue 25 May 10 @ 9:17 am
At first, sorry for my english, I´m austrian!
I got it working in Ableton Live 8 with that instruction http://nckn.de/2009/08/tutorial-automap-in-ableton-live-with-novation-nocturn/
follow the instruction to step 4 and then open VDJ.
got to config. then go to mapper. check the dropdown bar. In my mapping configuration there is "keyboard" at first and then "simple midi wrapper".
If there´s just the "keyboard" press the button to the right of the dropdown bar, and choose "search for devices again" (i think it´s called something like that, because in german it´s called "Erneut nach Geräten suchen")
if you´ve selected "small midi wrapper" the first key should be "MIDI_CLOCK" and the action should be "off".
When you´ve checked all these things, you can start to map your nocturn in VDJ. press "Key-Learn" in VDJ and select the button on your nocturn you want to map, then press "action-learn" in VDJ and select the function on your VDJ skin or search for a function.
HINT: To change between A/B you´ll have to map one button to the function "deck active select".
Hope I was able to help you....and my english was not too bad.
grz
PS: I don´t even think that you´ll have to follow these steps on the page. But try to get your settings like in number 1.
grz
Posted Sun 15 May 11 @ 1:13 pm
Hi guys,
A bit of topic but im in need of some help! I'm currently using virtual dj and a numark total control mixer with a pioneer efx 500 unit along with my numark dj io soundcard. Whenever i record i cannot record the effects of the efx500 but only the numark mixer effects, do i need any extra leads/soundcards or is it a simple config setting that needs to be changed?
Will appreciate any help :) Thanks.
Posted Sun 15 May 11 @ 3:18 pm
