Forum: VirtualDJ Skins
Topic: American Audio Velocity Mp3 CD DECKS - Page: 1
i use "Numark Virtual Vinly", i see that some one has made a skin for the American Audio Velocity Mp3 CD DECKS. when i try to download and install it, it tells me that it can't find Virtualdj. also the Description is not in english so i cant read it. any help would be great.
thanks for your time
the " SOUND INSURGENT"
Posted Wed 09 Jul 08 @ 11:36 pm
That skin has a size of 800x600.
I'm sure you have a bigger screen than that, so the skin will look really bad when you put it in full screen.
ok, but can you tell me why i get an error message saying that VJD can not be found. i thought that VDJ and NVV were the same. 1 more thing, you dont happen to make skins do you? if not could you point me in the right direction. thanks for looking and your time.
coulD i use the RESIZER and redo the skin?
It's probably because that skin was made for an older version of VDJ. Version 5.0 and up have the directory in your "my Documents" folder instead of the program files in the "C" drive. some older ones seem to work, some don't
i have no skill what so ever when it comes to things like making skins, could someone please make a skin for the American Audio Velocity Mp3 CD DECKS? this would make my YEAR!!! THANKS FOR YOUR TIME.
would 50 dollars due? let me know.
that looks GREAT, hope to see the finished product!
@quimisdj
I see both decks have exactly the same disposal.
I recommend to use my Skin Resizer Tool: http://www.virtualdj.com/addons/tools.html to code all the second deck very quickly.
Open the skin resizer, you will see two tabs at the top. Select the second tab.
In the first text field (at the top) paste all the code for the first deck.
Then select "Translation", and measure the distance between the center of an element on the left and the center of that same element on the right.
Make sure "Change chan number" is activated.
Then click on "Do the job".
You should get all the code for the second deck in a few seconds. ;-)
Experiencia Skin
Quimisdj
sweet!!!!!!! that looks great. how about the effects buttons, are you going to do something with those. either way it looks GREAT!! could i get a copy of that if its finished? let me know.
Of course, if when you are ready
And buttons to go Fx
Experiencia Skin
Quimisdj
Multi Boton
Loop And Hot Cue
(Can Leave Suggestions for Multi Button)
Mixer
Experiencia Skin
Quimisdj
NICE WORK!!! WISH I KNOW HOW TO DO THAT KIND OF STUFF.
Have you got that in English mate, lol
You make it look easy :)
Well what shall bring into English
Experiencia Skin
Quimisdj
Experiencia Skin
Quimisdj
83%
