IM TRYING TO DOWNLOAD THE TRIAL FOR MAC ON THE DOWNLOADS/TRIAL TAB. AND WHENEVER I GO TO THE LINK DOWNLOAD.COM IT ONLY SHOWS THE PC VERSION. PLEASE LET ME KNOW WHERE IS THE MAC VERSION ASAP.
THANKS.
THANKS.
Posted Wed 02 Jul 08 @ 7:07 pm
Hi gueromixx, As a pro edition user of NVV, u can just download the mac version from ur download center. U entitled to installed on 2 system, as of consist of 2 pc, 1 mac n 1 pc or 2 mac at all time at once. U can have access to both version so there no need for u to test the trial version tho;)
Posted Thu 03 Jul 08 @ 12:27 am
but i ihave the cue full version for virtual vynil and i want to try virtual dj as well because and having problems with the program. it stops sometimes. any link where i can downloaded or mac.
thanks.
thanks.
Posted Thu 03 Jul 08 @ 2:08 am
There isn't a trial version of Virtual DJ for Mac.
Posted Thu 03 Jul 08 @ 2:33 am
Apparently, Cue/VV n VDJ is the same program but different branding;)
Posted Thu 03 Jul 08 @ 5:51 am
Although I haven't used the Numark software, I've been told the same thing.
Posted Thu 03 Jul 08 @ 2:28 pm
but still can youll put it. for mac. every mac user shlould read this. if youll wanna keep selling software youll should put the mac trial too.
Posted Thu 03 Jul 08 @ 8:10 pm
I received Cue LE with my Numark Total Control and I can say YES, it is the exact same thing, it even has the link to the vdj site at the bottom.
The LE part means it will not launch or function at all without corresponding hardware, in this case the Numark TCO.
Posted Thu 03 Jul 08 @ 8:15 pm
What is your technical issue perhaps we could solve that?
What is your specification?
Best Regards
Simon Bangs
Numark Computer DJ Product Specialist
Numark Alesis Europe Ltd
Skype : NumarkSi
Best Regards
Simon Bangs
Skype : NumarkSi
Posted Fri 04 Jul 08 @ 6:35 pm
Its the same program different skin, Ive used both. (Personally I prefer the look of cue)
Posted Tue 08 Jul 08 @ 12:53 pm
hey do you know where i can get a serial number for VV if i downloaded it to my new computer and lost it.
Posted Mon 14 Jul 08 @ 4:49 am
