Anyone has that issue?
hardware:
Toshiba satellite A200
Windows vista 32 bit
Firewire sound card Roland Fa-66
When in auto mix it will work well for a while, then the sound will stop. the computer is not freeze. Virtual DJ is not freeze, i can push button, even drag the wave graph, but the play wont start again. And no more sound will be heard till, i close virtuial dJ and reset by turning off and on my external sound card. Then all will start back normaly till it doest it again. time it takes is always different.
If i play song onto media player, it will never failled. witch mean the sound card if fine, the drivers are fine..
It look its only in virtual DJ.....
Help please...
hardware:
Help please...
Posted Thu 12 Jun 08 @ 8:31 pm
yeah i have this samme proble, please help and i have vista as well
Posted Sun 12 Apr 09 @ 6:27 pm
What version do you have?
Posted Sun 12 Apr 09 @ 8:17 pm
ive actualy tryed multiple versions from my friend and they all do it
Posted Mon 13 Apr 09 @ 2:40 pm
download a current trial version if not all ready using one and see if the problem persists... thank you
Posted Mon 13 Apr 09 @ 2:48 pm
i have the current tryal version..
Posted Mon 13 Apr 09 @ 2:49 pm
have you cleaned out all other versions that you have been trying from your friend, if you don't the problem could still be there in the background...
Posted Mon 13 Apr 09 @ 2:52 pm
no yeah i have tryed every thing having to do with the program witch makes me think theres somthing with the vista or somthing im, not sure
Posted Mon 13 Apr 09 @ 3:54 pm
