does anyone know where you can get sonquie plugins for vdj because im looking for good ones.
Posted Thu 05 Jun 08 @ 10:40 am
not sure if your at the appropriate level but go to downloads then plugins and you find it there, fully qualified to use in vdj with no hidden nasties...
Posted Thu 05 Jun 08 @ 10:46 am
If you don't got the required level to download, you can download old versions of Sonique or Sonique's packs, the plugins are within. There are some sites that offers sonique plugins to users who still like to use the soft, even after descontinued.
Posted Fri 06 Jun 08 @ 10:59 am
soniques downloaded from any source other than vdj will contain viruses not all but some will so be vigilant, if you do go this route and download else where remember to scan before using... hope that helps
Posted Fri 06 Jun 08 @ 11:13 am
