WHich Laptop is the best one for Virtual DJ>> I'm looking to buy a new laptop, but I cant decide whether to go Mac or PC! For those of you who have used both, I would like to know your experiences with either one.
Posted Thu 05 Jun 08 @ 1:30 am
MAC MAC MAC MAC MAC
And don't you dare go cheap. Keep in mind, you can run windows alongside OSX on a mac.
Posted Thu 05 Jun 08 @ 5:22 pm
MAC, of course.
Posted Thu 05 Jun 08 @ 5:43 pm
Definately Buy a Mac. Never buy another PC again in your life... but for Virtual DJ only (until they fix everything), run XP on it through Boot Camp. See my post regarding what you can expect from Virtual on OSX. MacMall has some good deals on the 15" Macbook Pro. I just got the 24" iMac with the 512 VideoCard. Most amazing machine ever!!
https://virtualdj.com/forums/90629/MAC_Version_Technical_Support/Review_of_my_first_3_gigs_with_the_Mac_Version___its_Quirks.html
Posted Thu 05 Jun 08 @ 8:25 pm
Mac is the only way to go. You will never buy another machine unless you get a Mac Book, then you'll want a Mac Book Pro. I ran XP on bootcamp & the windows experience is even better. VDJ was stable.
Posted Thu 05 Jun 08 @ 9:02 pm
Honestly both system have its advantage...n I use both but i would say as the others... go for Mac.
If u only use audio actually PC lappy is good enuff n video so-so (it will werk too but depends on ur system) but if u wanna to optimise ur video and audio experience... best way is to go for Mac. (oops i say it again.hehe)
But again its based on ur preference and requirement anyway:)
Good luck n choose wisely!
Posted Fri 06 Jun 08 @ 12:48 pm
These are the specs on the MAC I had in mind. I'm not going to do video mixing or any of that. I just going to use it for mixing and thats it....
MacBook 2.4GHz Intel Core 2 Duo - Black
13.3-inch glossy widescreen display
2GB memory
250GB hard drive
8x SuperDrive (DVD±R DL/DVD±RW/CD-RW)
Built-in iSight camera
2GB memory
250GB hard drive
Posted Wed 11 Jun 08 @ 2:38 pm
Well, that black macbook is enuff for what u wanna to achieve;)
That looks like the latest generation of the macbook.
I believe the graphic card is the Intel GMA X3100.. even so it is good enuff also to use on video.
macbook - Good on audio but the video part may become jerky at times after lengthy usage but still werks great than most set up with PC)
macbook pro - Good on audio n video.
Regards.
Regards.
Posted Wed 11 Jun 08 @ 2:49 pm
I like the macbook pro, but I would hold off untill the summer redesign
Posted Thu 12 Jun 08 @ 9:21 am
Thanks Fellas................
DJ TURIZ
DJ TURIZ
Posted Wed 18 Jun 08 @ 12:14 am
